DIAdem
Coverting Text Channel to Numberic using Dict.Add function
I get an Error sgCmd = Replace(sgCmd,"#1",oChannel.GetReference(eRefTypeIndexName)) in this line "Invalid Character
Error in <TxtToNum.VBS> (Line: 208, Column: 61):
Invalid character
Message 11 of 15
(3,445 Views)
Hey Jcheese,
Where is this data coming from?  What file format is it being loaded from?  It's possible we can push the formatting you want into the DataPlugin being used, so all you have to do is drag the data file from the NAVIGATOR into the Data Portal and get the numeric channels you want automatically.
Care to send over a sample data set?
Brad Turpin
DIAdem Product Support Engineer
brad.turpin@ni.com
Message 12 of 15
(3,438 Views)
Brad,
Thanks for looking into this. I have added a uri, data set and test script to the thread in the last comment .zip file. Again as always I appreciate any help or advice you have for me.
J
Message 13 of 15
(3,431 Views)
I double checked the code again, using the example data you posted. Its working. The only issue I could think of is that somehow a non-printable character was included by copying the code to and from the discussion forum. The code is definitely working. Here it is again:
' Text to Numeric Channel
if programrevision > 1129 then
  Dim Channel,State,Dict3,t,TXT1
    IF Data.Root.ChannelGroups(1).Channels.Count > 0 THEN
      FOR Each Channel In Data.Root.ChannelGroups(1).Channels
        IF Trim(UCase(Channel.Properties("DisplayType").Value)) = "TEXT" THEN
        Call ConvertTxtToNum(Channel)
        Call ValChn(Channel)
        END IF
      NEXT ' Channel
    END IF ' Any Channels at all
END IF ' Program Version
Function ConvertTxtToNum(Channel)
  Call Channel.ChannelGroup.Activate
  for t = 1 to Channel.Size
  IF Dict3.Exists(ChT(t,Channel.Name)) THEN               ' Compares value in channel to value in dictionary
  ChT(t,Channel.Name) = Dict3.Item(ChT(t,Channel.Name))   ' changes the Key to the Item in the dictionary
  Else
    ChT(t,Channel.Name) = "0"
  end if  'dict3
  next
End Function ' ConvertTxtToNum()
Function  ValChn(oChannel)
  Dim   sgCmd
  Dim   ChnNumber : ChnNumber = oChannel.Properties("number").Value
  sgCmd = "ch(""#1"") = Val(ch(""#1""))"
  Calculate(sgCmd)
End Function
Message 14 of 15
(3,425 Views)
Thanks, works fine.  Must have copied a character somewhere.
Message 15 of 15
(3,401 Views)
