DIAdem
Create ASAM ODS Hierarchy
I'm trying to configure an ASAM ODS server. I already create the server, export the configuration and installed into the client computer. Then I'm able to connect from a client computer to the server but when i try to execute the script for hierarchy This does not work. My understanding from another forums is that the script "main.vbs" for create the custom hierarchy has to be run in DIAdem 2012 (I'm running with 2012 SP1 and is still not working).
The first thing that I notice is that after the conection the icons are not the same in the ASAM interface (NAVIGATOR) and then when I execute the "main.vbs" and "CreateASAMModelHierarchy.SUC" getting the attached error.
Can you please help me with this issue?
(6,474 Views)
Hi Naoa,
Try switching back to "My DataFinder" in the NAVIGATOR and then open up the "Data Stores" connection to your ASAM-ODS server again.  It sounds like your connection went stale or the server got turned off.
Brad Turpin
(6,465 Views)
Accepted by Naoa
Ni Naoa,
In case you have the same issue as nrin did, here's that solution again:
To connect to the NI ASAM-ODS server with AOP5 please follow these steps:
1. Open DIAdem NAVIGATOR.
2. Go to Settings - Data Stores...
3. Add a new data store. Either by using the first toolbar button or via the context menu.
4. Enter a name, select the AOP5 DataPlugin, and click OK.
5. In the following configuration dialog you will have to enter the computer name of the machine where the NI ASAM-ODS server is running.
(This information is also displayed in the ASAM settings dialog of the DataFinder Manager (DFSE)
6. Click the [...] button in the URL line. In the following dialog select your ASAM-ODS server.
7. Leave the two configuration dialogs with [OK] button clicks and open the new data store in NAVIGATOR.
8. Download the Hierarchy Creator script that was updated on Jan 27, 2014 and run it in DIAdem SCRIPT
Brad Turpin
(6,388 Views)
Thank you Brad, and yes it was the same problem.
(6,363 Views)
(6,362 Views)
