DIAdem
Create a 3DTable
Hello!!
I want to Create a Script for a 3DTable with the Help of Record. The following message is showed to me..
Thank you very much in advance.
Mosquito
(6,100 Views)
Hello Mosquito87,
to me it seems the compiler has found a syntax error in the script. Could you please try and add a ")" in the referred line?
Christopher
Christopher W.
Intern Application Engineering | NI Certified LabVIEW Associate Developer (CLAD) | NI Germany
(6,087 Views)
Hi Mosquito,
I'm guessing you didn't create the *.VBC file.  Would you post the VBScript you've created so far?  Or if you get this error message by clicking with the mouse in DIAdem, would you summarize the steps that lead to this error?
Brad Turpin
DIadem Product Support Engineer
(6,072 Views)
Hi Mosquito,
can you attach the script?
Ther error tells you there is missing a ')'. Without any piece of code I can't reproduce this beahaviour and can only tell you that there is missing a ')'.
Normally there doesn't occure such error when using the record function from DIAdem.
Kind Regards,
Philipp K.
AE | NI Germany
(6,050 Views)
