DIAdem
How to create dataset with constant time step from dataset with random time step
Could you tell me if it possible to solve folowing problem in DIAdem?
We have dataset with pairs of temperature and time of measurements, but time step is random. It's look like:
time:   1 min     3 min    7 min    8 min    8.5 min     13 min    17 min  .....
temp:   3          4          10         11        15             4            6     .....
We need to have approximated values of temperature with certain time step (for instance, 1 min). So, it have to be like this:
time:   1 min     2 min    3 min    4 min    5 min     5 min    7 min  .....
temp:   3          3.5        4          4.5        5           7           10     .....
Thank you in advance very much!
Alexey
(5,600 Views)
Hi Alexey,
Sure, the function you're looking for is in the ANALYSIS panel under the "CUrve Fitting" palette-- it's called "Linear Mapping".  You will need to create the desired X channel prior to calling this function, though, so you will probably need to use the ANALYIS function "Generate Numeric Channel" in the "Channel Functions" palette.
Brad Turpin
DIAdem Product Support Engineer
(5,585 Views)
Thank you very much for your extremely fast answer! It works perfectly!
Best wishes, Alexey
(5,568 Views)
