DIAdem
Cursors on the report by default
So I am making a TDR file and I want to place a cursor (or something that looks like a cursor) on my 2d axis from a channel property that holds the x position of the cursor in a TDMS file. I can see how to do this from the VIEW panel but I'm having a hard time finding out how to adjust the cursor (or even place one) from the Report panel.
Any advice on this would be greatly appreciated.
James
(5,243 Views)
Hi James
That is no build in funktionality. So you have to use events. This topic in the help gives you a good starting point:
http://zone.ni.com/reference/en-XX/help/370858M-01/reportapi/events/report_event_onaxissystem2d_irep...
Hope this helps
Winfried
(5,236 Views)
Hi James,
Interactively "placing" a cursor in REPORT with the mouse would require a custom event, as Winner mentioned.  But if you just want to automatically show a configured vertical line based on the X value stored in a property, you can use the "Constant" curve type and place your @@ expression into the X value column of its configuration.
Brad Turpin
DIAdem Product Support Engineer
(5,220 Views)
Thanks Brad, I think that will do what I need!
(5,196 Views)
So, for some reason this works:
@@Val(Data.GetChannel("[1]/Leg 2 Return Signal").Properties("Cursor_").Value)@@
But this always produces an "invalid character" error
@@Val(Data.Root.ChannelGroups(1).Properties("Control_Response_Start").Value)@@
The property stored there is a value something like 0.11732453465456
Interestingly, when I post
into the cursor field, I get the .1173 (etc) value, but it turns into the number, the equation is gone. Surrounding the equation with double @@'s produces invalid character. I'm not sure what I'm missing here.
(5,132 Views)
Still having trouble though I have new data. For some reason one TDR file accepts cursors just fine, but the other won't accept them at all. Strangely, when I copy a 2d axis with two 'cursor' curves on it into the non-working TDR file, the axis system actually shows up without any error message or warning, but the two constant channels with expressions are completely removed. Additionally, if I make a new constant curve and put say "@@4@@" into it, I get a bad character error (but only on the TDR that stripped out the curves and won't seem to take any expression in the axis systems).
Super weird. Any thoughts?
(5,111 Views)
