DIAdem
negative times a negative equals a negative
I have 2 channels that need to be multiplied,
Normal multiplication rules apply except when multiplying a negative times a negative I need the result to be a negative rather than a positive.
How would this be set up in the Diadem Calculator?
Not familiar with Visual Basic/programming.
(4,154 Views)
Hi CrocodileBic,
Scripting an if/then statement will be the best approach. Here are some resources you might find helpful.
Executing Channel Calculations in the Calculator
(4,113 Views)
Jeff,
Much appreciated!
CrocodileBic
(4,099 Views)
