DIAdem
Customize View, Report
is it possible to customize (e.g. remove items) the bar of a 2DAxisSystem in View ?!
And how can i customize/remove the "second bar" in Report (where font size,color,...) is located ?!
Thanks a lot
(6,200 Views)
Hi Andi,
I don't know what exactly you want to customize.
Can you attach some screenshots from your layout of the View and Report module. Please mark  the things you want to change or remove.
Kind Regards,
Philipp K.
AE | NI Germany
(6,185 Views)
i'd like to cutsomize/remove the following bars highlighted below:
Is it possible at all?!
Thanks a lot
(6,174 Views)
Hi Andi,
I don't see any possibility to access these bars.
It is possible to access the other bars via the barmanager.
The bar from the View module you haved mentioned belongs to the chart and not to the module.
I'm sorry for that.
Kind Regards,
Philipp K.
AE | NI Germany
(6,166 Views)
