DIAdem
dynamic channel management setting in Diadem 2012
Dear friends,
In Diadem 11.0, I changed the dynamic channel management setting:
But I can't change the dynamic channel management setting in Diadem 2012:
And my script can,t work normally:
Any one can help me? Thanks a lot!
(5,777 Views)
The screen shot in Diadem 2012
(5,772 Views)
Hi newlaohaier,
The 60 static, invisible channels that were created automatically at startup in 1990's versions of DIAdem became outdated when DIAdem 9.0 introduced dynamic (resizeable) channels 11 years ago.  I do not know if there is any way to resurrect those invisible static channels in DIAdem 2012, but I do know that DIAdem 2012 was the version that finally stopped supporting similarly old technologies such as *.AUT scripts, *.LPD layouts, *.COD dialogs, so it would be an understandable time to also shut down the old static channels.
I would be happy to help you convert your existing code to use the vastly superior dynamic channels.  Is that an option?
Brad Turpin
DIAdem Product Support Engineer
(5,746 Views)
Thank you very much! That's very kind of you!
And could you please send me your E-mail address to luobnc@schaeffler.com?
(5,733 Views)
brad.turpin@ni.com
(5,710 Views)
