DIAdem
*.DAT Supporting FILES
Is there a way to identify Supporting files of a DAT File?
i have a dataset, please see the snapshot of Dataset.
In that DataSet how do i identify Supporting files of a *.dat File.
(5,094 Views)
Accepted by topic author sunilpadikar77
The DataFileLstGet command should do the job for you
Option Explicit
dim datFilePath : datFilePath = "C:\Users\GrKrantA\kunden\WABCO_DataFinderBug\001026_4.DAT"
dim txt : txt = ""
dim cmpCount : cmpCount = DataFileLstGet(datFilePath)
dim i : For i = 1 to cmpCount
  txt = txt & DataFileLst(i) & VBCRLF
MsgBox txt
Be aware that there are additional commands
DataFileRename
DataFileDelete
That might do the job you try to fullfill
(5,081 Views)
your solution worked great. thanks
(5,069 Views)
Hi AndreasK,
(5,068 Views)
