DIAdem
DATAFILELOADSEL load group by name
Hi All,
I want to load a specific group of a tdms file into Diadem. Unfortunately there is a little race condition in my labview code that causes this goup to sometimes have index 3, other times index 4. No sweat, I thought, I'll just load the group by name!
Unfortunately the DATAFILELOADSEL  function doesn't seem to support this syntax, so I will have to first search for the index. Can anybody tell me how to first search the index of a specific group name?
BTW. I want to find the index without first having to load the whole file (they are large!).
Thanks!
Aart-Jan
(4,056 Views)
Hi Aart-Jan,
I had a similar problem some time ago and work around it by "registering" the data in the portal
Call DATAFILELOAD(filename,"","Register")
This goes a lot faster then loading the file and you can access group indices etc. Then you clear the data portal
Call DATADELALL
and load your specific data with DATAFILELOADSEL
Hope this helps.
DavidS!
also see:
(4,049 Views)
mm, got it working after all. Sorry..
CALL DATAFILELOADSEL(file,"TDMS","LF analysis/*","")
(4,048 Views)
Thanks David, indeed, registring was my workaround to be searching for channel names. Do you know how to write commands for searching groups by name?
My problem is solved, but I am interested in doing such things (including looping and such) in Diadem.
Aart-Jan
(4,046 Views)
Dear Aart-Jan,
I'm not sure if I got your problem correctly, but maybe this is what you're looking for:
For i = 1 to GroupCount   ' Loop over all groups
  If GroupName(i) = "TurbulenceLengthdScales" Then
    exist = TRUE
    Exit For
    else
    exist = FALSE
  End If
If exist Then
CAll Msgbox("Group has index no: " & i)
else
CAll Msgbox("Group does not exist")
End If
DavidS!
(4,042 Views)
