DIAdem
string length when using CHNAVERAGE
Hi all,
I want to average quite a number of non-waveform channels and ran into the problem, that the CHNAVERAGE function only accepts a 255byte long channel string. Working around it by using the "'[1]/Channel 1-'[1]/Channel X" syntax does not help, because channels are not in consecutive order.
Any Ideas???
David
... using Diadem 10
(3,862 Views)
Hi DavidS!
There is not any longer a length restriction in DIAdem 10.1 or newer.
May be a workaround in DIAdem 10.0 is to use channel numbers instead of channel names which increases the maximum number of channels you can specify in a 256 byte long string. Alternatively you may rearange the channels in the portal and then call the ChnRenumber function to bring the channels in consecutive order.
I hope this helps,
Christian
(3,857 Views)
Great. Thanx. wasn't aware of the Chnrenumber function!
DavidS!
(3,850 Views)
