DIAdem
DIADEM PDF EXPORT-Not Showing Multiple Pages
Hello All,
I have a problem while exporting the DIADEM report table to PDF. The Size of the table is above 4000. When I export these data to PDF it will just export the selected current page datas not all. But I would like to see the entire table in PDF or HTML report not just the current page table
How can I do that?..
Thanks in advance for your help...
Rigil
(3,415 Views)
Hi Rigil,
We can do this, but it's going to require an "Automatically Increasing" table as well as a script to loop through all the virtual "pages" of the table (that you don't see in REPORT) and append each sheet to an existing PDF.  PDF appending doesn't work in all versions of DIAdem (it's fairly new)-- which version of DIAdem are you using?  It would be best if you would post your data set and REPORT template (*.TDR) file or email them to me at brad.turpin@ni.com.  That way I could send you back a VBScript that you could use immediately without having to adapt it to your situation.
Brad Turpin
DIAdem Product Support Engineer
(3,408 Views)
