DIAdem
Diadem 10.2.1: "Variable is undefined: 'Root' "
I'm using now DIAdem 10.2.1 and have now a problem with Root-Object in DIAdem-Script. Everytime I call this object "Root", for example:
'-- VBS-Script-Datei
'-- Neu erstellt am 17.01.2011 08:54:16
'-- Ersteller:
'-- Kommentar:
Option Explicit  'Erzwingt die explizite Deklaration aller Variablen in einem Skript.
Root.ChannelGroups.RemoveAll
I received a msg from DIAdem: "Variable is undefined: 'Root' "
Can anyone help me with it?
Regards
Tuan Anh
(3,816 Views)
Hi tuananhto,
The DIAdem DATA-API was developed for DIAdem 11.0. So it is not supported in earlier versions. If you would like to use the DIAdem API's you need to update you DIAdem version.
Greetings
Walter
(3,812 Views)
Hi Tuan Anh,
The corresponding command for DIAdem 10.x and ealier is "DataDelAll".
Brad Turpin
DIAdem Product Support Engineer
(3,802 Views)
Thank you for your answer Smiley Wink
(3,777 Views)
