DIAdem
DIADEM too slowly when it runs.
I have a other problem with Diadem 10.2, when I execute the program, Diadem is blocked in script engine charge about 7 o 8 minuts. But I don't have this problem with DIadem 11 that run take less than 1 minute.
What is the problem?
Thank you.
Sara
Message 1 of 8
(4,876 Views)
Hello Sara,
We need more information about your environment and the circumstances when you are launching the different DIAdem versions:
  • Are you running the versions on the same PC?
  • Is PC connected to a net work?
  • Are you using the DataFinder?
  • Is a network server part of the Search Area?
  • ... etc...
Greetings
Walter
Message 2 of 8
(4,858 Views)
Yes I run Diadem 8.1, 10.2 and 11. But I uninstall all versions and I try only install Diadem 10.2 and the problem persist.
I use DataFinder yes, and the pc is connected to a net work.
Message 3 of 8
(4,850 Views)
Message 4 of 8
(4,850 Views)
Message 5 of 8
(4,848 Views)
Hi Sara,
What type and version of virus protection software are you running?
Brad Turpin
DIAdem Product Supprt Engineer
Message 6 of 8
(4,817 Views)
Eset NOd
Message 7 of 8
(4,806 Views)
Accepted by topic author s.g.m.
I solved this problem thanks!!!!
Message 8 of 8
(4,798 Views)
