DIAdem
Different Types of Cells in the same column?
Hello together,
Is there any way to set different Celltypes in the same column of a xtable?
For example to set the celltypes like this:
I can read the Type for every cell by:
Cell.ObjectType
But this property is "read only" so I can't change the celltype with this property.
Is there any way to set different types for the cells in the same column?
Kind regards
Tanja
(3,940 Views)
Hello Tanja,
No that's not possible. You can use only one cell type for a column and this cell type is fixed during the run time of the SUD.
Greetings
Walter
(3,918 Views)
Hi Walter,
thanks for your answer.
I think this could be add to the product suggestions, because this wold be a nice feature.
Kind regards
Tanja
(3,902 Views)
Hi Tanja,
That's a good idea. If you are willing you can add this to the DIAdem Idea Exchange forum and discuss this feature request with the DIAdem R&D group and other customers. Please have a look at www.ni.com/diademideas
Greetings
Walter
(3,900 Views)
