DIAdem
DIAdem 11.1 Service Pack 1 is available
The DIAdem 11.1 SP 1 is now available:
The DIAdem Team
(4,625 Views)
If you have problems with the installation process, please make sure that the following things are done:
  • Close the NI DataFinder in the system tray (right click and select "Exit DataFinder")
  • Copy the ZIP file to your DIAdem program directory (in my case that was "C:\Program Files\National Instruments\DIAdem 11.1")
  • Right-click on the ZIP file after it was copied and select "Run as Administrator"
That worked for me.
Otmar D. Foehner
(4,517 Views)
Thanks!
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
(4,121 Views)
