07-03-2011 11:47 PM
Is it possible to do probabilty distribution calculation in DIAdem??
For a some analysis, i need FFT and PDF(Probability Distribution Function) calculations.
I got FFT but unable to get PDF...
Just wanted to know where to find that function in DIAdem 2010.
Regards.
Solved! Go to Solution.
09-12-2011 09:35 AM
Hello Bijay,
DIAdem supports a lot of different statistic functions, but currently no distribution functions. The statistic functions are located in DIAdem ANALYSIS in the tool group "Statistics". In DIAdem REPORT you can create a PDF by opening the menu "File" --> "PDF export" or via command icon:
Greetings
Walter
09-15-2011 12:32 AM
Hello Walter,
I needed that distribution function for some analysis.
Thanks for knowledge sharing.
Bijay
09-19-2011 06:47 PM
Hi Bijay,
We can give you the standard normal distribution of a data set, but that's it. What else do you want?
Brad Turpin
DIAdem Product Support Engineer
09-20-2011 02:44 AM
Hello Brad,
Yes, that will be a great help. Currently i am doing that analysis in LabVIEW.
Bijay
09-20-2011 08:46 AM
Hi Bijay,
Here's an example you can run. It uses older DIAdem 10.x functions, but it still works in DIAdem 11.x/20xx.
Brad Turpin
