DIAdem
DIAdem 8.1 Ger(Sp1a) crashes
Does anybody know what is meaning if DIAdem crashes in a VB-Script with the
following report-messages ? Thanks for your answers !
233 **** Fehlerregistrierung am 22.04.2003 um 19:08:13 [Meldungsdatei:GLOBERR / Textarea:1 / Textnummer:409]
Bei der Ausführung des Befehls "AutEdScriptRun" ist ein Laufzeitfehler aufgetreten!
Fehlerart : ACCESS VIOLATION
Fehleradresse : 00028455
Modulname :oleaut32.dll
(Fehler wurde mit der Taste "Ok" quittiert !)
234 **** Fehlerregistrierung am 22.04.2003 um 19:08:25 [Meldungsdatei:GFSAUTED / Textarea:4 / Textnummer:1]
Fehler in (Zeile: 126, Spalte: 12):
Fehl
(4,444 Views)
Peter,
Can you upload the file(s) that create the error along with the data files you are trying to run this on?
Also, please let us know about the configuration of your PC (memory, OS, ...).
Otmar
Otmar D. Foehner
(4,444 Views)
thanks for help otmar !
Configuration: Win2kGer(Sp2) 256MB
It happens not with all datafiles(.dat) but with someone.
Unfortunately it's not possible to upload the scripts and data-files (not permitted)
(4,444 Views)
Peter,
Please ZIP the files and send them to me directly at this email address:
otmar.foehner@ni.com
Everything I receive will be handled with great confidence and will be destroyed after your problem has been analyzed.
Thanks!
Otmar
Otmar D. Foehner
(4,444 Views)
