DIAdem
DIAdem 8.1(Sp1a) Ger - "ChnTTICalc()" Final question
In accordance with FMVSS214 following is to do:
1) myself or from script:
Checking the sign regulations (SAE J1733) that acceleration values
have be positive absolute maximum values, also invert the 3 channels
(RIBS4,RIBS8,SPIN12) i.e. there is an side-impact from right side.
Filtering the channels with CFC_180
2) ChnTTICalc()function makes this
reducing the clock rate to 1600Hz (sub sampling)
remove the bias
filter with FIR100
transfer the reduced clock rate to the original one
Is this handling now correct ?
Thanks for help to all , and special to Walter
(4,109 Views)
Is is nearly correct.
Your part is:
Checking the sign regulations (SAE J1733) that acceleration values have be positive absolute maximum values, also invert the 3 channels (RIBS4,RIBS8,SPIN12) i.e. there is an side-impact from right side.
The function ChnTTICalc() makes this:
remove the bias
filter with FIR100
We checked this in the source code.
Walter
(4,109 Views)
thanks for your help walter !
(4,109 Views)
