DIAdem
How do I change the y-scale in the VIEW window of DIAdem?
How do I change the y scale of a graph in the "DIAdem VIEW" window of DIAdem? I can change the scale in the "GRAPH" window but there doens't seem to be the option of the graph cursor in this wondow.
Many thanks to anyone who responds.
(4,096 Views)
Hi Rob,
There is no setting you can access to change the Y scale of a DIAdem VIEW window. VIEW will always autoscale the window to the data displayed in the window.
There is a way though to change the Y scale:
Choose the 'Frame cursor' in the toolbar, select the y scale you wish to display by moving the upper and/or lower frame cursor and click on the 'Zoom' or 'Scroll' button in the VIEW window you are using.
I hope this helps you with your task,
Otmar
Otmar D. Foehner
(4,096 Views)
Many thanks, that's exactly what I was trying to do!
Rob
(4,096 Views)
