DIAdem
DIAdem Crash After Installation of New Windows Patch
When trying to run scripts in DIAdem, DIAdem crashes without any error message. This weekend the new windows patch was installed on my computer. What is the cause of the crashes when I run scripts that worked just three days ago? What can I do to fix it? Thanks.
(3,570 Views)
Hi HockeyDude,
I installed the new Windows patch recently as well-- on 3 computers, and the DIAdem 10.1, 10.2, and 10.2 versions on each computer still work fine.  What DIAdem version do you have?  Was this a patch for WinXP or for Vista?  Mine were all WinXP.
Brad Turpin
DIAdem Product Support Engineer
(3,542 Views)
Thanks for replying. Mine were all winXP, but I think the problem now is the serial evaluation. I am using "USeFileList" to pull in multiple repetitive data sets. The old scripts with it do not work and the old scripts without it do. Is there another way to write a similar command to "UseFileList"?
(3,534 Views)
Thank you for your help. I figured the problem out. Not sure what it was, but I just rewrote the whole entire thing letter by letter and it worked. Some odd reason a new exact copy works.
(3,530 Views)
Hi Hockey Dude,
I vastly prefer an explicit loop to the serial evaluation mode.  Here is example code to create the array of file paths from a multi-selection file dialog:
DlgTitle = "Insert File Dialog Title Here..."
StartPath = ProgramDrv & "Libr\Dat\"
FileExts = "*.DAT;*.TDM"
Call FileNameGet("Any", "FileRead", StartPath, FileExts, "Nul", True, DlgTitle)
FilePaths = Split("|" & FileDlgFileName,"|")
Call BubbleSort(FilePaths) ' sort the array of file names alphabetically
MsgBox OutputArray(FilePaths)
'-- BubbleSort() --                                               -- NEW SUBROUTINE --
Sub BubbleSort(NamesToSort)
  Dim i, SwapName, Swapped
  Do ' Until bubble sort of NamesToSort() is finished
    Swapped = False
    FOR i = 1 TO UBound(NamesToSort)-1
      IF StrComp(UCase(NamesToSort(i)), UCase(NamesToSort(i+1))) > 0 THEN
        SwapName  = NamesToSort(i)
        NamesToSort(i)   = NamesToSort(i+1)
        NamesToSort(i+1) = SwapName
        Swapped = True
      END IF ' Name(i) and Name(i+1) need to be swapped
    NEXT ' i
  Loop Until NOT (Swapped)
End Sub ' BubbleSort()
'******* OutputArray() ***                                        *** NEW Function ***
Function OutputArray(ArrayVar)
  Dim i, HdrMsg, Msg
  HdrMsg = "   i  " & vbTAB & "ArrayValues(i)" & vbCRLF
  HdrMsg = HdrMsg & "-----" & vbTAB & String(60, "-")
  FOR i = 1 TO UBound(ArrayVar)
    Msg = Msg & "  " & i & "  " & vbTAB & ArrayVar(i) & vbCRLF
  NEXT ' i
OutputArray = Msg
End Function ' OutputArray()
Brad Turpin
National Instuments
(3,503 Views)
