DIAdem
DIAdem Curve and Axis definitions
I have been doing the DIAdem Basic online course.
I thought I had a handle on the Curve and Axis definitions until I did the Knowledge Check.
 the image shows my selection but the correct answers shown to the right of my selection in small font size are the correct answers.
Can anyone explain why I am wrong.
Regards
Ray Farmer
(2,635 Views)
Hi Ray,
The answers in the far right column of your image are not all correct.  These are the correct answers:
Only channel name ........................... Time
[Group Index]/Channel name ............ [1]/Time
[Group Index[/[Channel Index] .......... [1]/[2]
Group name/[Channel index] ............ Noise_Data/[2]
Group name/Channel name .............. Noise_Data/Time
It's hard to tell exactly what you've selected in the middle column of your image, since the selected text is wider than the control hosting it.  I suspect that you have grasped this concept perfectly.
Brad Turpin
Senior Technical Support Engineer
(2,583 Views)
Hi Brad,
the picture you are seeing is the quiz review screen. After several goes at this I decided to see what the review came up with and clearly from the first answer it was saying I had it wrong when in fact I had selected the correct answer.
I am convinced there was a few of the earlier quizzes that were coming up with the wrong answer as well but I did get the option to retry.
Regards
Ray Farmer
(2,566 Views)
