DIAdem
DIAdem USB Stability Issue
I have noticed that DIAdem crashes during an unusual circumstance.
When I have external data on a USB storage device I open / load it to the data portal by double clicking on it.
Usually I either save or clear the data portal before removing the USB device but sometimes I forget to do so and when I try to clear the data portal after I have removed the USB storage device DIAdem crashes.
To my knowledge this occurs every time this situation is encountered.
Has anyone else noticed this?
I am using DIAdem 2012 on win 7 OS 64bit
Tim
(6,001 Views)
Hello Tim Z.,
can you give me some more info about the issue.
  • Which kind of file TDM/TDMS/CSV/...?
  • How big are the files. (In case of tdm the tdx file)
  • Just drag the USB stick without removing it I assume?
  • Can you share a file that shows ths behavior?
Greetings
Andreas
(5,975 Views)
Using TDMS files format
files are about 100 MB but I believe this doesn't matter it crashes no matter what the size.
Yes, the USB drive is simply removed without releasing it.
File size is very large and I cannot add as attachment
Tim
(5,943 Views)
Got it. We are able to reproduce and will fix it in a future version of tdms.
Thaks a lot for the feedback
Andreas
(5,934 Views)
