DIAdem
DIAdem View Map not loading
Recently I'm having problems to display the coordinates in the map view. Previously with same computer I was able, however I don't know the exact reasons but started to have this issue.
I have GPS data, longitude, latitude and speed, and I'm using this last one synch track.
I'm using a windows 10 computer.
(2,786 Views)
There are two things you should check.
1) Did you configure Map Source to OpenStreetMap 1 or OpenStreetMap 2?
2) When you open the DIAdem example like 'Map Display in DIAdem VIEW', It displays the map?
(2,753 Views)
It doesn't display from the beginning.
It seems the problem is due to Windows 10, IE security settings. It displays several warnings about HTTP/HTTPS in Diadem and IE and when agreeing them it starts working.
It never happened this before. So I'm thinking if it's related to a recent W10 update.
(2,730 Views)
It never happen this before. So I'm thinking if it's related to a recent W10 update.
(2,730 Views)
