DIAdem
Executing DIAdem Script form LabVIEW
My goal was to Load a TDMS File in DIAdem from LabVIEW and perform some calculations on the TDMS file from the diadem script itself.
But as I run the VI it opens DIAdem, I don't want to this rather it should run in the background(not open diadem at all). I tried a lot but couldn't succeed.
The script writes calculated data to an Excel File but every time I close the excel file it asks me to save it even if I scripted it to save it(Yes/NO).
If I click NO Excel asks me to save it. Is this can be corrected?
I have attached the vi. Please help me to solve the issue.OR is there a better way to do this.
(2,450 Views)
Hi himanshu25,
Did you check the following KB?
Run a DIAdem Script from LabVIEW
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QnfSAE&l
AmbrusG
Ambrus
Technical Support Engineer
??It's just business ??
(2,403 Views)
