DIAdem
DataAreaDel ChnAreaDel VBS commands are effectless
Dear Madam or Sir,
The above mentioned VBS commands did not have any effect on the channels I tried to use them for.
I asked my colleauge to test it on another platform and he reported the same inefficiency.
Please investigate the issue and give me a feedback about how to solve the problem.
Thank you in advance.
Kálmán Gangel
(5,765 Views)
Hi Gangel,
I tested the following
Call DataAreaDel("[4]/Temperature_1", 1, 5, "[4]/Temperature_3")
and
Call ChnAreaDel("[4]/Temperature_1", 1, 10)
with the DIAdem example dataset. This works fine.
Greetings
Walter
(5,747 Views)
Hello Gangel,
can you please confirm that the code is working in your case, as Walter proposed? If so, be sure to mark the answer. Smiley Wink It can be useful for others as well.
Thank you and have a nice day.
Jakub Prokeš
NIEE Aplications Engineer
(5,726 Views)
Hello Walter,
Thank you for you reply. I tried your proposal and it worked. But it still not working with my measurement data. I'm trying to figure out what the reason could be. If I find it out so, I will share.
Kálmán
(5,713 Views)
Hi Gangel,
thank you. Maybe we can try to help you on your own set of data if it is possible for you to share a part of it, and how is it behaving.
Jakub Prokeš
(5,708 Views)
