DIAdem
Subtracting to Value properties
I am trying to calculate and display the ESN_Mileage.  it seems this calculation below will only produce "9.999999999999" which is not correct.
DIM
ESN_M1, ESN_M2, ESN_Mileage
IF Data.Root.ChannelGroups(1).Channels.Exists("ECM Distance") then
ESN_M1=Data.Root.ChannelGroups(1).Channels("ECM Distance").Properties("maximum").Value
ESN_M2=Data.Root.ChannelGroups(1).Channels("ECM Distance").Properties("Minimum").Value
ESN_Mileage = (ESN_M2 - ESN_M1)
Call MSGbox(ESN_Mileage)
End if
(5,247 Views)
Could you please provide some clarification? is the total supposed to be 10 but it's always showing 9.9999? or does the calculation always produce 9.99999 regardless of what the inputs are?
Daniel G.
Semiconductor & Wireless
(5,229 Views)
Accepted by topic author Jcheese
My script was correct - had corrupt data
Thanks though
(5,226 Views)
