DIAdem
DataSetCommentXXX
When reading in a .DAT file produced by a data aquistion system, the group pulls in "DataSetComment001.." with metadata stored by the aquisition software.
Is there a way to change the title of these lines? I'd prefer to be able to change these to the actual descriptor, for instance, instead of having "DataSetComment001: JHU/APL" I'd like it to read, "Lab Name: JHU/APL"
Being able to script this would be most helpful.
Tamer
(5,081 Views)
You could Create a so called PluginPlugin.
  • Settings->options->Extensions->Dataplugins
  • Create a new and name it your way
  • Pick *.dat as extension
  • Pick Dataplugin (DAT) as filereader in the extended dialog
  • Create the plugin
  • Right click and edit the script
You see the following line that copies all properties
Call TDMGroup.Properties.AddProperties(StoreElement.Properties)
Now you can replace it by
      dim groupProp : for each groupProp in StoreElement.Properties
        select case groupProp.Name
        case "DataSetComment001"
          TDMGroup.Properties.Add "LabName", groupProp.Value
        case "DataSetComment002"
          TDMGroup.Properties.Add "my_author", groupProp.Value
        case else
          on error resume next
          TDMGroup.Properties.Add groupProp.Name, groupProp.Value
          on error goto 0
        end select
where you can map some properties to your needs.
If you can figure out if a file is not of your kind please insert an
RaiseError
to avoid all dat files to be proccessed.
It is also possible to do this in DIAdem itself.
The advantage of this aproach is that you can use NI Datfinder to search for files from "LabName"="JHU/APL"
(5,060 Views)
Thanks for the response, my script that's autopopulated doesn't have the Call TDMGroup line that you specified, this is what I have:
Sub ReadStore(File)
  'Tell the file how the string data is formed.
  File.Formatter.Delimiters = ";"
  File.Formatter.LineFeeds = vbNewLine
  'Create a file accessor
  Dim Block : Set Block = File.GetStringBlock()
  Dim DirectAccessChannel : Set DirectAccessChannel = Block.Channels.Add("FileData", eString)
  'Provide the data to USI
  Root.Properties.Add "datetime", Now
  Dim ChannelGroup : Set ChannelGroup = Root.ChannelGroups.Add("MyChannelGroup1")
  Dim ImplicitChannel : Set ImplicitChannel = ChannelGroup.Channels.AddImplicitChannel("ValueIndex", 1, 1, DirectAccessChannel.Size(), eI32)
  ChannelGroup.Channels.AddDirectAccessChannel(DirectAccessChannel)
End Sub
(5,045 Views)
When you create the plugin you need to extend the dialog using the >> button.
Then you can choose the file reader. This will generate a different script.
(5,025 Views)
See the screenshots for my process. I'm still getting the same script I posted above.
(5,015 Views)
If your plugin already exxists, tthe vbs will not be regenerated.
The following code does only work with an selected filereader plugin.
Option Explicit
Sub ReadStore(FromStore)
  Call FindAndCreateGroups(FromStore.Children)
End Sub
Sub FindAndCreateGroups(StoreElements)
  Dim StoreElement
  Dim TDMGroup
  For Each StoreElement in StoreElements
    If StoreElement.IsKindOf(eStoreChannelGroup) Then
      Set TDMGroup = Root.ChannelGroups.Add(StoreElement.Name)
      'Call TDMGroup.Properties.AddProperties(StoreElement.Properties)
          TDMGroup.Properties.Add "my_desc", groupProp.Value
        case else
          on error goto 0
        end select
      Call CreateChannels(StoreElement, TDMGroup)
    Else
      Call FindAndCreateGroups(StoreElement.Children)
    End If
End Sub
Sub CreateChannels(StoreGroup, TDMGroup)
  Dim StoreChannel
  For Each StoreChannel In StoreGroup.Channels
    Call TDMGroup.Channels.AddStoreChannel(StoreChannel)
End Sub
(4,999 Views)
