DIAdem
If - or
Hi!
I've got a little problem with the following code:
Dim i
For i=GroupChnCount(1) to 1 step-1
If ChnName(i)<>"Time" or ChnName(i)<>"AudioTime" Then
Call ChnDel(i)
End if
 I want to delete every Channel except of "Time" and "AudioTime". Unfortunately diadem deletes every channel.
When I choose just one of the channel names, the code works.
Thank you!
(3,482 Views)
Please use the object interface instead
Option Explicit
dim grpO : set grpO = data.Root.ChannelGroups(1)
dim i : For i = grpO.Channels.Count to 1 step-1
  if grpO.Channels(i).Name <>"Time" and grpO.Channels(i).Name<>"AudioTime" Then
    call grpO.Channels.Remove(i)
  end if
The even better soltion is to avoid loading the channels at all using reduced loading
Call DataFileLoadSel("C:\temp\Data.tdm","TDM","[1]/Time|[1]/AudioTime", "Load")
P.S.: The reason why all channels are deleted is because of the
or
The expression will always be true because a channel can't have both names.
It needs to be an
and
(3,442 Views)
