DIAdem
Datafinder Advanced Query "IsIncomplete" result equals true after 200 files searched
I have a VBS that runs an query that has been in use for quite some time but has reached its limit this week.  The limit reached is at 200 files, after that the "IsIncomplete" flag is set and am not sure how to increase this maximum value setting.  I tried the "MaxNoSearchResults" setting but had no luck.  I have a attached subset of the VBS I have been using, any input would be appreciated.
(5,100 Views)
Accepted by topic author Siriusly
Potentially
Navigator.Display.CurrDataFinder.ResultsList.Settings.MaxCount = 1000
is what you are looking for.
(5,087 Views)
After further investigation I found that I was setting the "MyDataFinder.Results.MaxCount" value after the search had been performed.  It needed to be moved before the search was peformed to return more than 200 elements.
Thanks for the feedback
(5,080 Views)
