DIAdem
How to get best quality of Report-slide for word document?
Hi
I use Diadem. In Diadem Report I copy the diagrams illustrations etc. to a word document. If I export as .EMF and then copy that to word I got the best quality. But it seems that its possible to make it better.
(And then I will print the word file as .pdf. There I used 4000 dpi to have the best quality)
(And I fitted the slides size ind Diadem-Report so that only the coordinate system with illustration is upon it)
So, am I doing right or is there any way to improve the quality ? How can I get the best quality?
Thank you.
(4,699 Views)
my first question is why are you don't you build your report and print it directly to a printer or pdf?
When you want to export snapshots from elements of the report you will only be able to export pictures.
If you have want to archieve the best quality i would suggest using DIAdem.
Best wishes
Philipp
(4,653 Views)
