DIAdem
Debug Include Script - jump into last line - not to Breakpoint
i have a script include to an other one.
when i set a breakpoint into the included script an run my diadem
the debugger will make a break but don´t show me the line where i set the breakpoint.
the debugger jumps in to the last line of the included script.
in the normal script (from where i call the include file) the breakpoint work as i aspect.
i know the problem with the debugger if you close a function (it is showed only with one line) , than it do the same.
i have expaned all functions - and 2 weeks ago the system works without no problems.
the only thing what is new, i changed my laptop.
the MS Debuger Function ist installed.
would be great to get help
thanks
maik
(6,575 Views)
Hi MaikThierer,
        when I set a breakpoint in a function of a subscript and call this function from a caller script the debugger jumps to the set breakpoint. If you close the function the debugger only jumps to the function.
        I can't reproduce your discribed behaviour.
Philipp K.
AE | NI-Germany
(6,378 Views)
i think i found the reason.
the diadem debugger used a pdm.dll with the version 6.0.0.8424
and this version was still used after the installtion of the ms debugger.
i copied the dll version 9.0.30729.1 into the path where diadem linked to, now it works
(6,375 Views)
Hi Maik,
I have the same problem. So i look for pdm.dll at my computer and i found some files with this name.
In which path do you exchange the file?
kind regards
  Uwe
(6,372 Views)
You can check the path
on my german version it is
Diadem Menüleiste -> Hilfe -> Info über... -> Script Engine
in english maybe (Diadem Menue -> Help -> Info About.... -> Script Engine)
here you can find the Debugger infomation
(6,369 Views)
I had the same problem with the script when it call a subroutine in other file. I changed the pdm.dll for newer version and my debugger stoped to work (yes, I didnt debug anything!!). So, I installed the Visual Studio and now it works very well!!
Anderson M. Takemoto
Instituto de Pesquisas Eldorado
(5,559 Views)
