DIAdem
Länge eines Array (length of an array)
Hallo,
gibt es ähnlich wie bei Kanälen - chnlength - eine Möglichkeit die Länge von Arrays abzufragen?
Is there any possibility to get the length of an array like chnlength?
Gruß
(6,776 Views)
Traderhans,
You can use the UBound(array) function to get the largest available index of an array.
-Josh
(6,765 Views)
Hi Traderhans,
Note that UBound() returns the upper bound (index) of the array.  Since VBScript arrays are zero-indexed, the number of elements in the array is actually 1+UBound(arrayname).
Brad Turpin
DIAdem Product Support Engineer
(6,757 Views)
Arrays in vbs are a little tricky.
Thats mainly because
dim arr()
does not create an empty array but an unitialized one. So calling Ubound(arr) will raise an error.
It will also fail to loop using "for each".
So I would suggest to never use "()" to define an array but
dim arr : arr = Array()
MsgBox "length=" & ubound(arr) + 1
dim arrElem
for each arrElem in arr
  ' here we can do something
Array() will create an initialized Array of length 0. UBound will give -1 as return value.
Usng this returing an array from a funtion works quiet well without having to check for exceptions if array is empty.
Option Explicit
Function GetElems()
  GetElems = Array()
  ' do some stuff
end function
dim elems : elems = GetElems
dim elem
for each elem in elems
If you want to dynamically grow an array you can use redim preserve.
Option Explicit
redim preserve arr(Ubound(arr) + 1)
arr(UBound(arr)) = "Appended text"
MsgBox "length=" & ubound(arr) + 1 & VBCRLF & arr(0)
(6,745 Views)
Danke / thanks!
(6,740 Views)
