DIAdem
Diadem 2017 script recording mode does not record calculator formulas
We've recently purchased Diadem 2017. In previous versions, with the script recording mode enabled, all calculator formulas were recorded on the script. I've tried to do this with Diadem 2017 and the formulas were not recorded. Any tips?
(3,629 Views)
The Calculator now has an new botton in top left.
"Prepare for Script and Copy to Clipboard"
which will put the needed line into clipboard.
Because the dialog can now be used while editing a script
you can directly insert it in your script.
(3,596 Views)
Yes, I´ve already seen that button. it's very usefull when you want to copy 1 or 2 formulas to the script, but sometimes I've to do this for 20 to 30 formulas. In the past, I had just to enable the script recording mode and all the formulas that I've calculated were recorded on the script. there's any way to do this on Diadem 2017?
(3,590 Views)
Accepted by Anderson_MAN_LA
HI Anderson, How are you?
I've tested this functionality  in DIAdem 2017 and works as expected, All formulas that I've calculated were recorded on the script. I've recorded my screen for your query
Diogo Aparecido
Applications Engineer II
National Instruments Brazil
(3,574 Views)
Thank you for the answer Diego. I figured out the problem based on your video. In the video you've used the "enter" button on the calculator. I was using "enter" on the keyboard. If you use the button on the screen, all calculator formulas are recorded on the script. If you use the keyboard the formulas are not recorded. Maybe this is a bug in this version of Diadem.
(3,567 Views)
I'm going to pass this issue for our DIAdem team, it's seems a bug, I agree with you
thank you
Diogo Aparecido
(3,564 Views)
