DIAdem
Diadem 3D Waterfall Diagramm
Hi all,
i would like to generate a 3D waterfall diagram out of a part of the added data file..
"FFT_Analysis_OLFL_190515".
The data-cut for the diagram is named "Hin-Max-Abschnitte"
File index should be x-axis
"Abschnitt1 to Abschnitt 9" should be y-axis
An behind "Abschnitt 1-9" are the informations for the z-axis
Actually i get out the tdms File from another person - i think we have to save the data in another data format (inside the file) to achieve 1:1 or easy diagram construction..
Maybe anyone can me help out..
Thanks in advance..
Regards
Michael
(2,514 Views)
Hi michihertkorn,
as some time passed since you posted the question, do you still struggle with creating waterfall diagram in DIAdem?
You can follow instruction directly from DIAdem help:
Hope this helps,
Patrik
CTA, CLA
Helping (sharing) is caring!
If the post was helpful - Kudo it.
If the post answered your question - Mark it as Solution.
(2,423 Views)
