04-30-2019
09:55 AM
- last edited on
08-03-2026
09:43 AM
by
Content Cleaner
I am faced with the problem that a function (nFileNameGet) is no longer available after an update of the GPI toolkit. Unfortunately, it is not known which initial version of the toolkit has been used to develop the extension, currently I need to provide a GPI extension for 64 bit platforms, so I used this GPI Toolkit:
https://www.ni.com/en/support/downloads/software-products/download.diadem.html#306756
The old toolkit has two "prototypes" for nFileNameGet in GPIFCT.H and some constants are defined in GPITYPE.H (/ * Constants for nFileNameGet * /), but both functions and constants are missing in the new toolkit - I also checked the deprecated folder.
Has anyone here already had this problem and can help me to find a replacement for the function? I've searched the documentation provided by the toolkit (pdf and chm) but I did not found something, that help me to fix that.
Best Regards
Lars
06-20-2019 07:14 AM
Hi Lars,
as I see this post is opened for quite long - Have you been able to figure our the solution to your case, potentially share it with a community?
