DIAdem
Diadem DAC support for PXIe systems?
I want to know if it's possible to install and run Diadem on a PXIe System (Controller and chassis) and use the DAC
for a fast measurement configuration and setup. Does somebody have experience with such configuration?
I know that I could use Labview but for fast measurement setups DAC in Diadem is quite perfect.
Thanks in advance.
(3,569 Views)
Hello pucon,
If an Windows OS is installed on the PXIe it is no problem to use DIAdem (including the DAC) on it.
Greetings
Walter
(3,553 Views)
Accepted by pucon
Just to complete Walters post above.
DIAdem DAC works with any NI PXIe hardware that is supported by NI MAX (Measurement and Automation eXplorer), including global virtual channels. If you have Windows XP or later on the PXIe system, this will work fine ...
     Otmar
Otmar D. Foehner
(3,530 Views)
