01-13-2011 04:27 AM
I want to know if it's possible to install and run Diadem on a PXIe System (Controller and chassis) and use the DAC
for a fast measurement configuration and setup. Does somebody have experience with such configuration?
I know that I could use Labview but for fast measurement setups DAC in Diadem is quite perfect.
Thanks in advance.
Solved! Go to Solution.
01-13-2011 09:00 AM
Hello pucon,
If an Windows OS is installed on the PXIe it is no problem to use DIAdem (including the DAC) on it.
Greetings
Walter
01-14-2011 07:18 AM
Just to complete Walters post above.
DIAdem DAC works with any NI PXIe hardware that is supported by NI MAX (Measurement and Automation eXplorer), including global virtual channels. If you have Windows XP or later on the PXIe system, this will work fine ...
Otmar
