DIAdem
Diadem Function
hi there,
I'm using Diadem version 9.1 and I tried using the function ChnOrdAFCalc to do an order anlysis on my data values. The parameters which I've set are:
    OrdAFType = "Order"
    OrdAFMaxOrder = 16
    OrdAFFiltReCalc = 50
    OrdAFSigWeight = "None"
    GenXBegin = 0
    GenXEnd = 3000
    OrdAFRevolStep = 100
    OrdAFFFTLength = 1024
    FFTAmplType = "Ampl.RMS"
    FFTAmplExt = "No"
    FFTWndFct = "FlatTop"
    FFTWndPara = 10
    FFTWndChn = "time"
    FFTWndCorrectTyp = "No"
    FFTCalc = 0
    FFTPhase = 1
As you can see above, the parameter setting for "FFTPhase" = 1 and I expected to see a phase spectrum being produced after running the function. However, this is not the case when I run it. Are there any other parameter settings I need to alter/change or is there a solution to this?
Can someone help? Thanks!
(3,657 Views)
Hi greasystains,
The order analysis function does not allow to calculate the phase spectrum. The teached FFTPhase parameter is a little bit confusing here. ChnOrdAFCCalc internaly runs the FFT. Therefore the FFT variables - which are the same when running the FFT command ChnFFT1 - are reused and teached.
The standalone FFT however allows to calculate the phase.
By the way here you can find an Order Analysis Tool for DIAdem which gives you more help in using ChnOrdAFCalc:
I hope this helps.
Christian
(3,626 Views)
