DIAdem
displaying signed 8 bit integers using a data plug-in
Hi there,
I'm currently using DIAdem 10.1 and I'm writing a data plug-in in order to read binary data. What I'm missing is a data type "eI8" to read and display 8 bit signed integers. Obviously, to get the data into a channel, I have to use the data type eByte, but how do I make DIAdem display it as a signed value in the data portal?
Many thanks in advance!
Stefan
(4,163 Views)
Hello Stefan,
you can use the method:
Value = Object.GetNextBinaryValue(eDataType)
eDataType Aufzählung.
Bestimmt den Datentyp des auszulesenden Werts.
2 - eI16 16-Bit-Integer.
3 - eI32 32-Bit-Integer.
4 - eI64 64-Bit-Integer.
5 - eByte Byte.
6 - eU16 16-Bit-Unsigned-Integer.
7 - eU32 32-Bit-Unsigned-Integer.
9 - eR32 32-Bit-Real.
10 - eR64 64-Bit-Real.
Rebecca Fox
(4,143 Views)
Hi Rebecca,
many thanks for your reply. Unfortunately, I think this doesn't help me because the data type I need would be "eI8". If I use eByte, the sign information is gone and if I use e.g. eI16, one byte to much is read.
Is there any other solution?
Anyway, thank you very much so far!
Stefan
(4,134 Views)
Hello Stefan,
with eI8 it should work. I will look that it will be corrected in our help!
Rebecca Fox
(4,128 Views)
Hi Rebecca,
thanks a lot! It works with data type eI8.
Obviously, I wasn't bold enough to just try! 😉
Kind regards,
Stefan
(4,123 Views)
