09-20-2006 08:22 AM
09-26-2006 02:37 AM
09-26-2006 02:54 AM
09-26-2006 04:01 AM
01-16-2007 06:10 AM
1. If you are im modul Navigator and you'll press the button 'delete internal data' the settings are changed from 'ansi' to 'unicode'
2. If you have loaded data in 'dataportal' and delete the data via the contextmenue the settings also will change
Rem.: We use Diadem DAC Kit/ Bundle with the VLM
On my local machines with local licenses there is no such behaviour!
