DIAdem
scale report
In the attachment you will see a typical report format that we have, in which we devide the x-axis into 3-4 different parts.
where for example:
1st part of x axis: The time difference between two ticks represent 20 ms (this is the part we have no important information on the signal)
2nd part of x axis : The time difference between two ticks represent 5 ms ( the distance between two ticks on the graph is always the same) this is the part where we have a closer look(zoomed so to say) on the signal, since the things we investigate happens in this part...
3rd part: It again represents 20 ms.
etc.
For the Y axis:
There is a certain length for 1unit. For different curves 1 unit may represent certain amount of mm, kV, kA , etc.
Finally my question is: Is it possible to generate such reports with DIAdem?
thanks in advance
kaan
(3,725 Views)
Hi!
It is possible to create such a report in DIAdem.
You have to create your own X Channel with the X values with increment 0,02 or 0,005.
This channel will be used to plot your Y Values.
On the Y side you have to "Norm" all your Y values to your 1 Unit length.
You must make your own calculation to create your Y Values which will be plotted in the Report.
Here an image of a report I created. The X Channel has 2 blocks where the data is plotted every 5ms
Regards
Ken
(3,712 Views)
Hi Ken,
thanks for the answer.
I actually wanted to know if it was possible using the features of the Report panel of DIAdem without modifying any data.
Your solution is ok, but it requires :
1-splitting the waveform channel into X and Y channels
2-Modifying the X channel (thus creating a imaginary one) without changing its length (if the length changes either X or Y channel will be shorter than the other, which will result in wrong representation of the curve)
    In the area where you want to have a better visualization, one has to increase the distance between two sequential x points by a factor . For example (x2_new - x1_new) = 4*(x2_original - x1_original). This will change the time range in the x channel.
3- Loading the original Y channel with the imaginary x channel in the report.
4- In report ; deleting the numbers in the x axis (because they are wrong values)
5- mark the time value between two ticks(1unit) in different parts of the graph.
And after all this is more Analysis then reporting !
I hope there is an other way to solve this problem
regards
Kaan
(3,698 Views)
Hello Kaan!
The short answer is: No
As far as I know is there no build in way. You need a multiple X axis scaling, but there is only a single scaling in DIAdem.
Every solution aproach will result in a calculation process or an uncomforable layout design.
I see two aproaches:
  • Ken's aproach (calculations required)
  • Multiple coordinate system side by side with manual X-Scaling (verry bad to handle)
Sorry that I can't give you hope for a simple and good solution.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,693 Views)
