10-09-2007 02:32 AM
Hallo,
kann man Diadem 10.2 nachträglich noch auf Deutsch umstellen oder muss direkt bei der Installation Deutsch ausgewählt sein ???
Dann hab ich ein Problem, ich Installiere das Deutsch Paket, aber leider ist die Oberfläche in English.
Könnt Ihr mir sagen Warum?? Könnte es am *.lic file hängen?
Danke
10-10-2007 02:57 AM
10-13-2007 06:58 AM
Hallo,
ich hatte Diadem schon einmal Installiert und aus versehen in English kann es jetzt sein das er diese einstellung immer wieder übernimmt ?
Oder könnte es schon wie gesagt and er *.lic Datei liegen ???
MfG
10-15-2007 01:10 AM
10-15-2007 01:22 AM
03-31-2009 04:01 AM
I moved to Germany a few months ago and in one of my tasks I have to analyze large data files and also generate histograms with some macros that I wrote. Some of my colleagues use the German version of DIAdem 10.2 and when I asked our IT rep to install it on my PC, I was told that it was only available in German.
From what I have read, the English version is a different installation. Is it possible to install an English version of DIAdem 10.2? If yes, would there be a problem with the license files since it's a different language?
Kind regards / Gruessen
Noel
03-31-2009
08:21 AM
- last edited on
12-19-2024
09:53 AM
by
Content Cleaner
Hello Noel,
You can download the English version of DIAdem from this Website and activate it with your license file. The license file (and in the end National Instruments) doesn't care if you use the English or German version of the software. All the layouts, data file and Scripts should work either way, so there shouldn't be any problems from that end either.
Use this link https://www.ni.com/en/support/downloads/software-products/download.diadem.html to search for the correct version of DIAdem, and select the same version you are currently using in German in English (make sure to select with or without DAC and to get the Service Packs if available).
Hope that helps,
