DIAdem
Diadem2017 - XMS ChnXMSCalc doesnt save results
Hi im using crash analysis function for counting 3ms, with following code
Call ChnXMSCalc("", chActC.GetReference(eRefTypeIndexName), 3, 0, "in one peak", false)
The last parameter is "XMSNegSigValCalc" and when its set to false, everything works and it saved results to Result folder of properties(new in 2017). When i set it to True, it doesnt save it to properties and i dont have a result, is it bug or its logic?
Because in help its written: "If the XmsNegSigValCalc variable has the value TRUE, DIAdem calculates the X ms values for the positive signal section separately from the absolute value for the negative signal section. DIAdem sets the value for the other signal section to zero. DIAdem saves the X ms values of the higher absolute acceleration in the result variables."
Im using 64bit win7ent SP1, i5-5300U, 8GB and Diadem 2017 64bit (17.0.0f6657)
(3,270 Views)
Hi Lukas,
It looks like R&D is going to create a CAR for this issue.  Hopefully it will be fixed in either DIAdem 2017 SP1 or DIAdem 2018.
Brad Turpin
DIAdem Product Support Engineer
(3,196 Views)
