DIAdem
Difference between DIAdem 10.2 and DIAdem 9.1
Can anyone refer me to the web page where i can find the differences in DIAdem vbscript commands (deprecated, syntax etc) between DIAdem 9.1 and DIAdem 10.2? We are upgrading our application from DIAdem 9.1 to 10.2 and have come across few issues with the values returned by certain commands. For example, i have attached the code snipped which returns different values in each DIAdem versions. I appreciate your response.
Dim MinVal, Index
 MinVal = CMin("Time Zero") Index = Find("Ch('Time Zero') = " & MinVal)
  The values returned in both the versions are
DIAdem 9.2:
MinVal = -1.4653898078996E-04Index = 1DIAdem 10.2.1:MinVal = -0.00014653898079Index = 0
Best Regards
Haja
(3,460 Views)
Hi Haja,
I don't think such a web page exists.  In this particular case I think you're running across a difference in how often DIAdem re-calculated the characteristic values of a channel.  Try adding this command before the CMin() line:
Call ChnCharacter("Time Zero")
ChnMin = CMin("Time Zero")
Or you can use the CCh() function that automatically re-calculates the quantity you're asking for:
ChnMin = CCh("Time Zero", 1)
If that doesn't help, please send us a representative data set.
Brad Turpin
DIAdem Product Support Engineer
(3,449 Views)
