DIAdem
can I backup my custom datapllugins
I have several dataplugins that I have created in diadem. I am wondering if I can back them up or export them in case my computer crashes so I don't have to try and make them all again
Nevermind I think I figured it out
Message Edited by chandler on 10-24-2009 08:48 AM
(3,546 Views)
In the DataPlugin Settings Dialog you can just select your plugin and press the export button or seloect export in the context menue.
Afterwards you will get an uri file that contains your dataplugin.
It is sufficient to double clieck those uri file to register the plugin on a clean machine.
If you export the plugin encrypted you will not be able to edit the script any more.
So please choose the normal export to backup your plugin.
(3,542 Views)
