DIAdem
Displaying last value of channel in DIAdem Report
I need to call out on a report to display the last value of a given channel in the data portal.  I know its something like @chn....@ but i dont know how i can tell it to use the last value given in the data set. Help would be much appreciated.
Brian W.
(4,956 Views)
Hello!
You can write:
@ChD(CL("Channel_Name"), "Channel_Name")@
ChD gives you the value at a determinated line of a channel. CL is the channel length.
Best regards
Ken
(4,953 Views)
When I am using the ChD command to display a specific line/value of a channel, how do I format the the channel value (e.g. d.dd) to avoid excessive decimal places?  Thanks.
(4,574 Views)
Hi Brian,
I think this is what you are looking for:
@@str(ChD(CL("Channel_Name"), "Channel_Name"),"d.dd")@@
The "str" function converts the real value into a string, and the "d.dd" formats the string to two siginificant digits behind the decimal comma.
Otmar D. Foehner
(4,568 Views)
