DIAdem
ORDER ANALYSIS
Hi all,
I  m really very confused,i need to have order analysis for that i m using the function "Call OrdATParaSet(XW, Y, X1, ) " in result i m gettinga number of channels "time,rotational speed & orders magnitudes" i am using the data available in labview examples(order analysis) while doing analysis in labview it's giving correct waveform but while doing analysis with same data files in diadem it's always giving order magnitudes=0, so what can i do for this?
thanks
Nidhi
Message 1 of 12
(6,335 Views)
Hi Nidhi,
The LabVIEW order analysis functions assume that you have a tachometer channel to track the instantaneous engine speed.  The DIAdem order analysis functions assume that have an RPMs channel to track the instantaneous engine speed.  Which do you have in your data set?  What type of order analysis do you want to run (3D frequency spectrum, 3D order spectrum, 2D order cut, etc.)?  The DIAdem function you listed below "OrdAtParaSet()", does not run an order analysis calculation but only sets up the correct input channels-- note that the last parameter here is the RPMs channel I mentioned above.
Would you be able to post your starting data set?
Brad Turpin
DIAdem Product Support Engineer
Message 2 of 12
(6,326 Views)
Hi Brad,
so sorry by mistake i have written that function actually i have used " Call ChnOrdATCalc(XW, ChnNoStr1, ChnNoStr2 ) " function in order to have order analysis in time domain, & i want 2d  order cut plot.
Nidhi
Message 3 of 12
(6,310 Views)
Hi Brad,
One more thing i want to know in order analysis(time domain) what is that reduction mathod(RPM,TIME)?
Nidhi
Message 4 of 12
(6,307 Views)
Hi Nidhi,
Would you please post a sample data set that you are wanting to analyze?
Brad Turpin
Message 5 of 12
(6,296 Views)
Hi Brad,
Thanks a lot for your help, i solved out all the problems.thanks again.
Nidhi
Message 6 of 12
(6,257 Views)
Hi Brad,
again i m stuck in one problem. i have used function "Call ChnOrdATCalc(XW, ChnNoStr1, ChnNoStr2 )" in event click of dialog box, so if there occurs any error, it is taking "IDCancel " as Dlgstate even though i m pressing ok, so what to do to sort out the problem? i want to have dialog box(user defined) display of that error.
Nidhi
Message 7 of 12
(6,204 Views)
Hi Nidhi,
This use case requires that you briefly suspend the standard VBScript error checking, like this:
On Error Resume Next
Call ChnOrdATCalc(XW, ChnNoStr1, ChnNoStr2)
ErrNum = Err.Number
ErrMsg = Err.Description
ErrSrc = Err.Source
On Error Goto 0
IF ErrNum <> 0 THEN
  MsgBox "Error " & ErrNum & ": " & ErrMsg & vbCRLF & "Occurred in " & ErrSrc
END IF
Brad Turpin
Message 8 of 12
(6,189 Views)
Thanks Brad,
It's working fine.
Nidhi
Message 9 of 12
(6,158 Views)
Hi Brad,
I am sending you a data file for which i have to perform order analysis, values are coming,but how do i cross check whether values which are coming correct or not?
Nidhi
Message 10 of 12
(6,123 Views)
