DIAdem
Does DIAdem support CAN-FD when used with Vector Hardware
Vector provides software that makes DIAdem communincate with Vector hadware, specifically the VN1630. The VN1630 supports CAN-FD standard, can DIAdem work with CAN-FD messages?
(6,714 Views)
unfortunatelly I cannot tell you if CAN-FD is supported by the DIAdem driver for the Vector or not. The DIAdem driver for Vector hardware is developed and maintained by Vector. So they might be able to answer your question.
Regards
Rainer
(6,691 Views)
Thakn you for the reply. I'm also wondering if DIAdem supports CAN-FD over all with any driver?
(6,682 Views)
Hil,
CAN-FD is supported by the latest version of the NI-XNET hardware and driver software. You can acquire CAN-FD data with DIAdem by using NI-XNET and the DIAdem driver for NI-XNET.
Regards
Rainer
(6,677 Views)
got it, Thank you
(6,643 Views)
I'm just testing a Beta-Version of the new "Vector-Driver for DIAdem" which supports CAN, CAN-FD and FlexRay using Vector Hardware-Interfaces. It is a 32Bit-Version, but a 64Bit-Version is announced for September.
Date of Release and costs must be asked at Vector.
(4,353 Views)
