DIAdem
report 2D-Axis label syntax
Hello Community,
Does anyone know the syntax off the top of their head to reference a curve channel in Report 2D-Axis label?  I'm trying to label the X-axis with the Waveform x-unit using:
 @@Data.GetChannel("[18]/WindupFFT_tag_5.00").Properties("wf_xunit_string").Value@@
But instead of "[18]/WindupFFT_tag_5.00" , I would like to use a generic channel reference to the curve channel.  Can't seem to make this work using the same syntax that works in a script...
Thank you.
(3,186 Views)
Accepted by topic author Chris_P_SD
Hey,
What exactly do you mean with "generic channel reference"?
Where and how do you want to define the channel that is used?
You can create a new axis system, add any waveform channel to the axis system, double click the x-axis label and you will get this "generic" reference:
@@ChnName(CurrChnNo)@@ [@@ChnDim(CurrChnNo)@@]
If you drag and drop the waveform unit property to a script you can get its VBS code equivalent that can be copied to the x-axis label like you already explained it. This will also work but will be fixed to a specific channel whereas my previous example with CurrChnNo will use a channel that matches the axis position.
Christian
CLA, CTA, CLED
(3,178 Views)
HI Christian,
Thanks for your response.  What I didn't realize was that when graphing a waveform channel, using the label
for the Y-axis gabs the "Unit" property of the curve channel, whereas applying
to the X-axis label grabs the Waveform x-unit.  I thought this syntax was referring to the same curve and thus would return the same value in both instances, but that is not true.
Is there some way to generate a MsgBox or debug output when applying @@<code>@@ in a report so that you can see what the code actually references?  The way I had to figure this out was to assign @@ChnDim(CurrChnNo)@@ to both axis labels and then look at the list of properties for the curve channel to see what property it was actually referring to...
Thanks for your help.
Chris
(3,152 Views)
